1 - 20 of 41 Posts
Say you had a 12.5:1 468, A 10.5: 496 and A 9.5:1 509 BB2 PLUS heads cam shaft 258/268 @.05 and .680/.70 lift 110LS and 2-750,s witch one would make the most HP? The 509 having a 4" crank.
Probably the 468, maybe the 496, but not the 509.
Fir fun I just ran some numbers. The engine build software I use says 798 for the 468, 791 for the 496 and 781 for the 509. It's not a sim. program like DTD, it's more of an engine design program.
Platinum Member
The 468 motor race gas or mixture of it
the 496 premium gas
the 509 could get away on 87-89
Each motor makes power but at what cost of fuel and can you get it where you want to boat ?
Me I would run the 509 and add a big nitrous w/ alky if I need the extra power
from time to time
468 hands down with that cam. 700hp on Gears dyno.Just ran a 475. Same basic cam, AFR 305s with cnc chambers and single 1050. Made [email protected]
Numbers are a little high for what your talking about. a 509 with 9.5 compression making 781 hp not on you life. Dream on.
Now steel. You know you pulled that out of your hat. Not enough info provided. What sre you up too????????? :confused:
It was just showing trends. All I changed in the program was the bore/stroke and compression. I didn't even change fuels, so it's not going to be very accurate.
And FWIW...even with 9.5:1, you put a TR and the right cam with those heads, turn some rpm, and I guarantee you can make 780 hp. If you can't, you need to find another way to make a living.
Discussion Starter #16
496 it is
That settles it 13.5:1 496.
Grady a 13-1 496 is a great combo Tint loves his!!!
Dad is going to build a spare 496 13-1.
we loved the pump gas 498 we had!!!
just build something!!!!!!!!!!!!:partyguy:
:cuddle-smiley: How your within about 10 hp. thats what my Dyno would say.
your Dyno must be very close to the one we go to.
Numbers are always lower than anyone elses.
yet they Perform wonderfully :hmmm:
1 - 20 of 41 Posts
