Double ditto on that!!! I will not use a sealer on the pump to housing gasket as I have pulled the apart when a adhesive sealer has been used and not real happy by the time it pops loose. There maybe disagreement on this but I have never seen or had a leak at the suction housing to intake. So it appears you have the pump back and will be ready to get wet soon. Send a P.M. or drop a dime you know me " I'm in " Mgrease it both sides
x3, i've got 3 or 4 suction gaskets in my workbench that i ordered thinking i was gonna need 1 during a overhaul for someone. most never tore cause they were greased, so i just reused em. i do bowl/droop gaskets the same way.grease it both sides
