1 - 2 of 2 Posts
My intake is leaking how hard us it to take out and reset?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Not to hard but scary! Heat is your;e best friend. After ALL the bolts are out put a floor jack directly under the intake and lift almost off the trailer. The putty they use to set turns to butter once heated enough. focus heat on intake NOT the fiberglass just till it starts to bubble the paint, focus on the rear at the transom and work forward in circles till it pops. When you think it;s hot enough add more heat, you will know when the boat settles back down on the trailer add more lift and it will lift out. M
1 - 2 of 2 Posts
