There are a lot of variables there. What Nozzle, Nozzle size, impeller size, impeller make, Hi-Helix, pump brand, pump model, suction housing, intake, loader. Just about every change you make to the pump will affect those numbers.
it also depends where you're taking the pressure reading...
VERY roughly, i see about 135psi at 4000, about 200 at 5000, about 270 at 6000, and about 310 at 6450. emphasis on the "about", because these numbers tend to oscillate a little and i don't stay at 4000, 5000, or 6000 very long. this is with a 3.125 nozzle id...
knowing the pressure and pipe i.d., you can calculate flow rate.
A forum community dedicated to performance boat owners and enthusiasts. Come join the discussion about offshore racing, performance, modifications, builds, classifieds, troubleshooting, maintenance, and more!
