We never answer dumb questions here, but we are pretty big on dumb answers. With a leak down test you fill the cyl with air from a compressor, and measure the rate the cylinder leaks down in %. More than anything, you really end up just listening to the carb (leaking intake valves), exhaust (leaky exhaust valves)and crankcase breathers (leaking past rings) for air to find out where it is leaking. Leak down measurements can be a little misleading if you aren't accustom to doing it. And as far as the ring seal goes, it really only means something at whatever place the piston is at when your test. Which means you need to test at different places in the bore.This may be a dumb question but i dont have much of an ego and would appriciate the knowledge. I was curious as to the process of a leak down test and how it differs from a compression test. Thank you
I have just always set the cylinder at TDC:This may be a dumb question but i dont have much of an ego and would appriciate the knowledge. I was curious as to the process of a leak down test and how it differs from a compression test. Thank you
Since 99% of the folks here are asking about pleasure/performance engines. Someone with a full out race engine is not going to ask questions here.
I prefer to use leakdown readings to establish a trend. Or a "change" in readings.
The only time the actual reading itself is used to make a decision is when there is a significant change.
If the engine is making good power, not blowing too much oil, responds to tune up changes etc. Then the readings are what they are. Plot them on a trend chart. Make a decision that when they deteriorate down to a specific value then tear it down. And unless any reading does not have a big change run it until then.
Leak down and oil filter contents are primary things I look at to determine engine health.
Oh if a valve is blowing by - You can "STAKE" the valve with air pressure in the cylinder and it's possible some carbon etc just might be expelled sealing the valve again. That is a whole lot easier to check than pull the head.
It's immediate.thanks for all the input guys. That is the time line for the pressure drop? ie. 10% drop in 1 minute?
In my picture above the gauge on the left is attached to the feed regulator the gauge on the right is connected to the cylinder you can see they are both reading 100 psi. If the piston had a hole in it the gauge on the right would be reading zero (100% leak) and air would be blowing through the crank case. If I hurt a valve the gauge on the right would be reading 85 psi ( or a 15% leak) and the air would be coming out of the intake manifold or the exhaust pipe.thanks for all the input guys. That is the time line for the pressure drop? ie. 10% drop in 1 minute?
