1 - 16 of 16 Posts
Discussion Starter · #2 ·
got back on it today some.
removed all the front suspension
another pile of parts
Discussion Starter · #3 ·
update got some more done,
Off to the shop
new shop for repairs
Discussion Starter · #4 ·
deep thoughts
New home for the next month or so.
More pictures to follow :cool1:
Discussion Starter · #5 ·
update, the shock towers are removed, prepping for the new cross member
decided to replace the rocker panel also, after this decided to replace the whole rocker panel.
Upstanding Member
Nice!!
Looks like a serious undertaking! You probably know this but just in case you don't make sure to check the cowl vent area for rust. Very common to get water in the interior through there.
Whats going under the hood?
Discussion Starter · #7 ·
I have heard about the vents, yes they will be getting checked, I am installing a 390 back in it, it is a original s-code car from the factory with a C-6 Automatic in it.
Discussion Starter · #8 ·
more updates, replaced the Radiator support,
not happy with the replacement support, so now looking for a nos one, here's the top of the new one I got
looked like someone beat it with a hammer, so it goes back.
removed the rocker panel :eek:
Discussion Starter · #9 ·
OK, the front suspension & motor mounts are starting to go in.
new front Radiator support that is not beat up
Even though I know better. You make it look like you know what you are doing. Looking good Pat. Can you paint???
Discussion Starter · #11 ·
I just saw this again, I cannot take the credit for the welding of the kit, having it done, I cannot weld good enough to trust myself with the front end, as far as paint, well, we will see how that goes, it should be back in my shop in a couple of weeks, then the rest of the suspension gets mocked up along with mocking up the engine and trans to see if anything needs to be adjusted.
Keep us updated I can't wait to see the end result of car man!
Discussion Starter · #14 ·
updated pictures, I have a rocker panel
Mounts all welded in now
new radiator support
little by little it is getting there, it comes home next month, still need to replace the r/s qrt panel
& some misc welding
Discussion Starter · #15 ·
from the welding shop to the body shop
Discussion Starter · #16 ·
little more progress
She comes home on Thursday :happy:
1 - 16 of 16 Posts
