1 - 20 of 24 Posts
Here is my Gator Jet Bass Boat engine compartment. Vortec 350, four M-30 batteries, Stealth on the fly charger, etc. The two large storage bins are removed so you can see the engine & battery areas. The bilge area needs cleaning! I made the pics large so you can look around.
www.highflowdynamics.com
LO
Is that an all aluminum LS3 motor? If so, can you please let me know the following:
  • How did you set up the fuel return to the tank
  • How did you set up the O2 sensor on your exhaust or are you doing away with O2 sensor all-together
  • Are you running a T-Stat and if not, how are you regulating the water temp since these engines (I'd assume) like to run under constant temp rather than it being fluctuated like on a normal jet application
  • How does it perform for a jet application, i.e., max speed, hole shot, etc.
Thanx in advance...
i'm back!!
and the cp19 sorry for crappy pics but they are scans....and it gets zoomies for racing....lightningheaders for the lake,
1 - 20 of 24 Posts
