Here are some props I have for sale. All props are going for real cheap and some are new.
SUZUKI RH 14-1/4X26 175.00
SS RH 21P 48-88442a4- 21p 175.00
MIRAGE LH 25 p brand new 200.00
MIRAGE LH 21 P 4813703-21 175.00
SHOOTER OUTBOARD PROP RH 431718 4 Blade 25 P
13-1/4 200.00
iam not sure Iam running 3 blade 21 on my boat know I was told if i went to a 4 blade or 5 blade 24 i would get more top speed my boat is a 22 ft cole pretty heavy boat what do you think
Discussion Starter · #5 ·
i am not sure I am running 3 blade 21 on my boat. i know I was told if i went to a 4 blade or 5 blade 24 i would get more top speed my boat is a 22 ft cole pretty heavy boat what do you think
If your boat jumps out of the hole I would go to a 23 3-4 blade stainless prop and you will see a little more top end. You dont want to het to high cause then your boat might have a tough time getting up on plane/out of the hole.
Thats a tough one. I tried all sorts of 3 blade props on my BAJA/TANKER ship and boat never got above 60 and that was on a good day with the windblowing in the right direction, no gas and just me in the boat. LOL:)devil.
I think that sounds like a good idea it is worth a try, but alot of other things to keep in mind like your HP, gearing and your outdrive etc. I am no expert with props but that is my take. I will see if I have a 4 blade ALF 1 23-24 P prop for you.
