1 - 20 of 28 Posts
easy nuff to pick up some 1/2 in thick flanges but im having hell findin 1.75" 180* ubends with at least 8inches of straights on them, this way i can order 4 180* bends, slice them in half and have the 8 zoomie pipes i need. tried several mandrel bending places but noone seems to wanna bend them for me, jus wanna sell me off the shelf ubends with 6inch straights. anybody gta net source for what im looking for that i can jus paypal and get em coming?
looking for:
1.75" mild steel 16g
3" bend
at least 8" from the tangents(8" straights on both ends)
of course i can cut down the extra length if i find some too long, but aint gna build a ugly set of zoomies and have 2 pipes welded together on each pipe, that'd look like shitttt:p
looking for:
3" bend
Are you going to put 8 turbos on them?:)grn:)sphss
Just another Wannabe
If you get the wider radiused bends, you can get the 6" legs to look pretty good. I did this set and laid them WAAAAYYYY back, but this is how they look.
damn man, that's mean looking!! im diggin it:)devil
im gathering materials for my uncle to build him a set of zoomies for his lil 17ft earl smith tunnel, gna end up runnin a 370ls motor in it with a 250hp shot of nitrous(for now lol). if 6" straights are plenty long nuff, id go that direction, pretty sure 6" will clear the hull.
wannabe, think 6" of straight on a smallblock is plenty?
ive got his c.o.p. ignition done, a carb'd intake bought and here, gna use a 750dp he already has , but gta do exhaust now and a set of zoomies will look pretty cool , get embee to coat em.
looking for:
3" bend
http://www.stahlheaders.com/Web Tube Bends_1.html
Some of those longer legs on that sheet look pretty good. :)devil
I was actually surprised that the 6" worked as well as they did. They should be enough for a small block. The length in the actual bend made up quite a bit more distance than I would have thought not building them up. Also, 6" was the shortest of all of the legs. They were actually a little longer. And where else are you going to get a set of stainless zoomies for a total cost of $200? Really?!
Highaboosta
just a ski boat with bark
Cool looking zoomies, what diameter are they? :)devil:)hand
wasnt hard to find what i needed in ss, but these zoomies are for 1 season then he'll either hang em on the wall or they'll end up in spam section here. he wants to try a big shot of nitrous on a ls this season, and if that's not nuff to be as quik as he wants, we'll put a s488 on it with a qft blowthru and make over 1000 with the same longblock that we'll only get 700hp out of with big nitrous. he's not looking to be the quickest anymore, jus wants a cool ass smallblock setup like nobody elses.
Village Idiot
If I remember right they were 2.25". I don't like the huge sewer pipe look and sound (and also think the increased velocity could help based off of the CI and RPM range). We were going to try the funny car zoomies, but it would not have worked all that well out the side of the hull.:)sphss
Paul
Village Idiot
Oh, and with that diameter the evacuation line we welded in (Buzzz welded in actually since we wanted them to look nice) worked quite well. It did a great job of pulling vacuum from the crankcase. I was impressed.
Paul
I was just curious Paul, I have a friend that swears by zoomies on his NA deal but I'm not entirely sold on his set up. I couldn't tell if those were 2-1/4" or 2-1/8" tubes so I figured I'd ask. That set you posted there sure looks nice, I didn't think I could lay them back that far using 2-1/4" tubes on mine but I guess I figured wrong some where. lol
Have a great day :)hand
Discussion Starter #14
Paul
you're able to draw evacuation with zoomies that short? if that's the case, we better do the same on the zoomies we're building, be that much easier to keep oil in the motor instead of in the boat:)sphss
Village Idiot
Loren, I have heard a few people that say they pick up MPH and drop ET when the switch to zoomies, but they are always running over 120 in the first place, so I don't know if it is aerodynamics, the crossflow helping with scavenging or if their headers were just that bad in the first place.
Paul
Village Idiot
Surprisingly yes. I have seen some people use a longer tube on the back hole and have a scavenge line attached to it. I would not have believed it myself if I had not put my finger over the line that was attached and felt how hard it was drawing. Buzzz did some special shaping to the evac fitting to make sure it did not restrict too much and still would create a decent vacuum. I was impressed.
Paul
Discussion Starter #17
Paul
coooool dealio, you're giving me an idea:)devil we were talking about block venting last nite while trying to decide on how much radius to order the ubends with, and only drawback we came up with runnin zoomies was lack of evacuation ability. makes sense tho it'd work after you mentioned it, any higher pressure/high velocity movement will pull from a pitot in the flow with no pressure or velocity, kinda like siphoning gas with a garden hose in the tank and air hose to get it started siphoning.
1 - 20 of 28 Posts
