Thanks. Was really happy with it. Found out my mechanical fuel pump wasn't keeping up so I'm going to switch to a belt driven and be worry free and also need to make a few mods to the linkage but other than that, it was a great day. :thumb:Nice numbers man congrats! Otta be a runner fo sho
They're the BB-2's.Which Brodix heads are those?
Tim
I've heard those are inconsistent as well. They had a guy with a similar engine to mine with one and it wouldn't keep up. Plus for a few bucks more I can do a belt set up and just have piece of mind. Both Bob and George at Vrbancic were leaning towards a belt driven also so gonna go with their recommendations.PS&B1;3074890 said:Get a Clay Smith pump!![]()
It was just a suggestion.I've heard those are inconsistent as well. They had a guy with a similar engine to mine with one and it wouldn't keep up. Plus for a few bucks more I can do a belt set up and just have piece of mind. Both Bob and George at Vrbancic were leaning towards a belt driven also so gonna go with their recommendations.
I appreciate all suggestions and input.It was just a suggestion.
It will easily handle 825 hp consistently and trouble free.
My Racepump doesnt require a return line and I have ran it up to 30psi of boost & over 7400 rpms with 555cid without any trouble. 150psi & 450gphI appreciate all suggestions and input.)THumbsUp All the options were considered and gone over at the dyno but i'm going to stick with Bob and George's recommendations. They were super cool guys and were explaining that the problems with the mechanical pumps is the more heat they get in them and the longer they run, the harder it is for them to keep up the pressure. I watched mine on the dyno work great when it was cold but after a few pulls it dropped considerably and that was supposed to be a pretty good mechanical fuel pump
I'm looking into either a waterman set up or a BLP one. Hoping to be able to get away with not having to plumb a return line to the tank and I know BLP makes a nice pump with an internal bypass. Plus this way, if I ever do some upgrades i'll already have a fuel system to support more power. I'd rather spend a couple extra bucks now and not have to worry about burning up pistons because my fuel pressure was dropping while I was cruising down the river.
Appreciate the input.My Racepump doesnt require a return line and I have ran it up to 30psi of boost & over 7400 rpms with 555cid without any trouble. 150psi & 450gph
Race Pumps Fuel Systems
Thanks man. Carbs are 950's with 84's all the way around. PV's are blocked off.Nice build!. Real similar to mine.
468 dart heads, hyd roller, 420 B&M, only pulled mine to 6200. Made 6.9psi at 7% under. 802hp. 8.8:1 static. Cam is a 236/245 .630 lift 114lsa.
Your afr ' s look real nice. I've got 84p/92 secondary with 8.5pv. Non boost reference. Holley 850's. My afr was 12.2 at 6200 on the dyno with that combo.
What's your carb setup? Are those the actual manifold temps on the sheet?
Huh, I thought they had a return line on them.My Racepump doesnt require a return line and I have ran it up to 30psi of boost & over 7400 rpms with 555cid without any trouble. 150psi & 450gph
Some of their set ups I do believe require a return line but some don't. If you look on their site, they have a diagram for a lot of different applications and it shows their recommend plumbing.Huh, I thought they had a return line on them.
No return line. On some of the Car applications with high underhood heat problems they add an idle bleed that returns to the tank. But no need for it in a boat. No return on mine. just a pump with a separate reg for each bowl on the carb.Huh, I thought they had a return line on them.
No.
