1 - 20 of 21 Posts
Member
Today while prepping my block for paint I went to set the heads on and the little guides were missing. I guess when they machined the block they didn't put them back on. Where do I go to get these.. thanks :D
First stop is back to the machine shop.
When they look at you dumbfounded and stutter about not having any idea where they went, I'm not so sure where the next step is. OEM Mfr. could get them I am certain. Might take a week or so.
Member
That is not the response I was looking for:D
It's what we do
Any shop that assembles engines will have them. We have tons. You'll just have to be lucky enough to find somebody open at this time.
Good luck
Member
That's the one I wanted to hear. Thankyou:D:)hand
Engine junkie
They are available new too, Like BD said, no problem to get at any engine machine shop.
Depending on how good (or old) your local NAPA store is, they may have them.
Just go get a piece of all thread and make some temporary stud guides, slide heads in place, install bolts. That being said, are block dowels even necessary especially if you got a helper? I've installed heads several times without em. Nothin too serious ever happened:D
TEN THIRTY ONE
Uhh??? :)eh:)
uhh what?? I'm not saying leave the all thread in the block. Just use as a guide then remove and replace with bolt. Same principle as a studded block or am I missing something?
Since the dowels are a much closer fit to all 3 parts than the fastener is, they locate all 3 parts exactly, and the fastener only provides clamping force.
There are helpers at the factory too, why do they still machine for and install them?
IMO yes, they are necessary, or they wouldn't be there in the first place.
Member
Discussion Starter #17
Thanks Tim but I think I can find some around here. I will hit Bob Mckrays Monday:)coffee
Member
Discussion Starter #19
Thanks Busby. Hey do you want to buy some mattresses?:D
1 - 20 of 21 Posts
