1 - 1 of 1 Posts
COLE TR-4 BGF
Used Littlefield 8-71 polished alum. alch/nitro hundred and twenty degree billet rotor blower. The Kobleco K-11 rotors are stripped on the tops with nylatron and sides with Teflon. With a billet front cover as well as billet front bearing plate and a billet rear bearing plate. The rotors ride in precision hi speed bearings that are timed by steel gears and have nylon plugs installed in the lightening holes to push more boost into the intake manifold to boost the power level. Top opening is 10.50" x 4.50" and a retro pie bottom opening. This blower has been drilled in the rear four spots for fuel nozzles and this blower will accept a Bug, Bird, or most of todays Carbon Fiber injectors with a 13.250" on center bolt pattern. Blower has fresh Teflon strips and new seals and is ready to go racing.$3000.00
1 - 1 of 1 Posts
