I have seen pictures of your boat.There is a lot of performance to gain.I would take your boat to either Jack of MPD OR SHOEMAKER.I do not see any ride plate,my guess you do not have any shoe in your boat.you may need a back cut shoe for some lift.The loaded will help keep your jet stay loaded with water.They will need your boat there to measure off the bottom to get you close and what type of blocker/loader you may want.Do you have a inserts on the outlet of the jet? I dont see a pump support bracket.How about a INDUCER to load the pump also?I would drill and tap for a fitting to take inlet pressure to get your intake set up right with the problems you have had in the past.Take your boats to a performance jet boat shop to get it right the first time.I have run Jacks stuff for many years with zero headaches.Good luck.The boat looks nice
