1 - 20 of 24 Posts
I pulled off the intercooler and found this inside my intake. Can someone tell me WTF this is? Is it some kind of repair?
Thanks in advance.
Nate
Some guy
Thanks in advance.
Nate
It's difficult to see in your photos, but I guess you mean the dark epoxy in the runners? I don't recognize that intake but it looks like someone spent a great deal of time, and the epoxy was put in the runners to get it to flow where it was wanted or needed, perhaps a drag race deal originally?
Is this something I need to take out, now that its a marine motor now? Or is it one of thoughs "if aint broke, dont fix it" things.
Thanks
Probably an epoxy to fix the port job. Could of needed to be raised or reshaped so bad it was needed. I don't see what its hurting.........
for what its worth.Why mess with it. It looks like some work was put in there for a reason. When the runners get extended like that it makes the intake think its"longer". I wouldnt mess with it, especally if you disturb the epoxy.
Wow...someone's got a TON of work in that plenum. Whatever it is, it was done intentionally and I wouldn't mess with it. Do you have a spacer to go with that intake?
Edited to add: OK...I see this is a turbo deal. Does the bottom of the intercooler match the plenum shape?
"It's HONDO, honey"
I'll second that. LEAVE IT
Lurker
I am just basing this on the pictures and first thought, prolly way off! :)sphss
Looks like a bunch of distribution work has been done. If the "from the top" pictures are taken from the rear, the black stuff would be "dam's" (or is anyway regardless of position) trying to cure the dreaded #7 rich/#5 lean deal on a stock GM firing order by keeping the "floor fuel" out of there. You can see a little added in other area's I think to do the same but in smaller adjust's.
As I said, just a quick observation! :)hand
21 Daytona
:)hand
Ditto
Exactly. This work wasn't done without a flow bench. It also looks like the carb mounting flange (4150 my guess) has been layed way back over the runners to add more volume for the FI. I'd sure like to see a pic from a little further away, and see the intercooler as well. That's some pretty decent work.
Lurker
After looking at it again, my first thought was wrong (imagine that). If the picture is from the rear the dam would lean out #7 which is a lean cylinder to start with. In a manifold like that #5 usualy gets the big dam.
But....it is mentioned that he pulled the intercooler off so is this injected? The manifold doesn't appear to be as trick as I first thought, but maybe just a typical clover-leaf type plenum entry with some cut off of the carb flange?
1 - 20 of 24 Posts
