1 - 20 of 40 Posts
· mo balls than $cents$
all u do is grind a way a little bit of the nozzle?
you'll have to adjust the cable to pull it alil higher as well and maybe notch the divertor cable mount arms some, you'll see what i mean.if its hyd divertor, it may take up the slack automaticlly, not sure.
do u know of any laws regarding use of the jetovator? if im just crusin on the lake is it legal to use?
not in oklahoma:D we roost each other all the time, hell i got roosted by my own boat this past weekend:p
i have herd there are laws against doin it to close to the shore or other peeps , wether it be boaters or swimmers.
· Registered
split bowl?? im new to the jet boat scene can u explain?
does your nozzle bolt onto the bowl? i am assuming it does since your deal is somewhat newer with a dominator pump. if so you can put a "wedge" in between it and make it go higher. i put a 4 degree in mine and its goes really freakin high but it slows you down big time. all show and no go. :D
1 - 20 of 40 Posts
