So...I'm thinking about putting an LS1 engine with a Bravo XR outdrive in my next boat. I'm having a hard time finding a suitable flywheel and coupler. That's probably because I know very little about outdrives in general. Currently I have a PTO for the LS1 for my jet; but I know that's not how an outdrive works.
I need a flywheel and coupler, correct? That's how an outdrive connects to an engine, right?
The bolt pattern on the crank flange bolt pattern is 6x3.11", std Chevy diameter, 168 tooth. Anyone know if I can use the 496/8.2L Mercruiser stuff? If not...what else is out there?
Thanks!
Thanks!
