1 - 20 of 33 Posts
I ordered Autolite 2593 plugs for my engine and what I got was Autolite AR2593 plugs (Autolite Racing). I will be running a mag and I was wondering how I'm going to properly set the plug gap, then I wondered the same thing even if I wasn't going to use a mag. Maybe I'm overthinking again but I'm stumped (again). Thanks!
We use to cut ours like that and gap it like you would any other plug for the most part. Your just gapping from the electrode to the strap. They just won't last as long.
.020 from the center of the plug to the strap.
We run .018 with the old Vertex and never fail to fire right up......I just use a .018 feeler gage and lay it flat on the electrode........and set the strap to a slight resistance when sliding in and out. Be sure to index the strap away from the piston to eliminate any possible contact and to assist flame travel. ( I don't necessarily buy into the flame travel part, but it is what I've been told.......).......Ray
PS as far as lasting, we're on the the third season with a set of Autolite Racing plugs. The last set, the old school type, lasted 15 years. They were still working just fine, but an engine explosion destroyed 2 of them, so I replaced the set.........
.016-.018 Depending on the motor tune. If points .035. If electronic whatever the distributor manufacture recommends. Also curious as to what head you are running with that plug.M
Some guy
Pro Comp aluminum heads
Have you tried to install one of those into the head? You may end up needing a 39 series plug, 3924, 3923 are cheap "street" plugs(available at Autozone), 3911 and 3910 are "racing" numbers. They all are .750" reach, gasket seat 14mm plugs with the smaller 5/8" hex.
I've been running .020. I just opened it up to .025 w/ the new MSD mag. Been running 33* plug says it wants a little bit more, gonna try 36* and fatten up the top end. I'll let you live in my boat if you bring the Zommies.
:)hammers Yea, you're right, 2 steps forward and three steps back. They don't fit. The hex is too big, I can't put a socket on them to tighten the plugs.
You can take that brand new MSD mag and ... :D
Hi Terry, I'd have to at least stay in your Chevy for those zoomies. LOL
Some guy
The "racing" plugs were like $4.50 each, and the 3923 or 3924 are easy to get, less than $20 for a set of 8. Don't know what engine, compression, etc you have, but maybe just get a set of the 3923.
Cantard
Any special reason you chose an autolite over an ngk? Here in the snow autolites are not that common. Special order actualy.
Discussion Starter #14
I got the racing plugs completely by accident, it was a parts house mix up. I paid the same price as "normal" Autolite's are priced.
For Sale, set of 8 brand new Autolite Racing... :D
The guy that put my engine together said for me to get Autolite's or NGK's, my carb guy said to get Autolite's. So I bought the wrong Autolite's. :)sphss
Discussion Starter #18
Why are you running a Mag in the first place??
Because they are simple, because there isn't a MSD box or a Unilite pick-up to fail, because a good friend of mine has run a mag for 20 years without any failures, and because they look cool.
I'm probably going to catch some heat for the last one, lol. :(:(
Distinguished Member
You forgot to add that mags make way more HP than MSD's..... :D
1 - 20 of 33 Posts
