1 - 2 of 2 Posts
i have a mallory single point marine dist.. and was thinking? do i need to run the ballast resister like some of them or if i run an internal resisted coil am i ok ? thanks robbie
Spiral out
Either, or.
Preferrably the external resistor cause you are then able to run a 12v lead straight to the coil for startup purposes only.
To add.....this 12v source should come from the starter solenoid....so it is only "hot" when the starter is engaged.
1 - 2 of 2 Posts
