1 - 15 of 15 Posts
I have a Sanger mini daycruiser with a Ford 460 in it with a Mallory YLM567EV distributor . I'm not getting any spark . I checked the grounds and all the wiring and everthing seem ok . Do the magnetic breakerless ignition modules go bad ? If so how often do you need to replace them ? I'm no motor head and really need some help . Any advice would be great . :)bulb
Cantard
Yes they can, check and see if it is rusty or has any cracks in it. I am guessing you have checked for power at the coil?
Here is how i recently solved my mallory problems...
Runs much better now...:)sphss
I'm not much of a mallory fan...but they can/do work. Does your set up have a ballast? If it does take a multi meter and check the voltage on both sides. I have a module if ya want one cheap.. If you want to pay shipping there and back I may loan it to ya.
What would you like for it ? Where are you located ?
That red is difficult for me to read.
The modules in Mallory distributor's do go bad. Years ago I had to replace the module in my Mallory several times until I got tired of replacing it and I got rid of the Maollory all together.
Can you tell me what it was like when your module went bad . Was your motor running differant or did it just stop working . What did you replace it with ? Thanks
Calling all motor heads in the Grass Valley ,ca. area
Well I found a MSD distributor , ignition box , coil , and wires on craig's list . Bye Bye Mallory ! I'm looking for for somebody in the Grass Valley ,ca. area that can do the swap . I really need to get back on the lake soon .
1 - 15 of 15 Posts
