whats a goodtime cost?
gonna pick your brains with a stupid question.i dont claim to know anything about distributors or what goes on inside them. i am running a mallory points distributor, part number YL624AV2. i want to put a conversion kit (points to electronic) in it. which one of the following will work on my dist. and how simple of a task is this? thanks.
1. http://www.jegs.com/i/Pertronix/751/ML-181/10002/-1?parentProductId=746414
2. http://www.jegs.com/i/Pertronix/751/9ML-181/10002/-1?parentProductId=750194
if none of these will work. please let me know which one will.
mallory points dist. part number YL624AV2
Looks to me like either will work in a YL Tom
It wouldn't be moving the rotor, cap, teeth on the cam or anything. I don't see how it would mess up the timing but you guys know more than me......hopefully
Why trust this to chance , would always recheck for total timing! "dwell" (points gap and operation) can change timing so that the change from points (where your timing setis currently satifactory?) this could likley change when you disturb that by installing the Electronic plate, pickup and mechanism for the breakerless setup . Without regard I would check it .Also its prime time to remove the top breaker plate and see not only what advance springs are present but what kind of mechanical advance is there and available to you Tom
Thanks tom. Gonna go ahead and check total timing. Was 34 total. Gonna shoot for that again. Thanks again. Great information as always.
