1 - 2 of 2 Posts
Lurker
Moon Mark IV BBC timing cover for blown motors
Got this Moon timing cover for my Mark IV BBC build, but found out it's intended for a blower motor, and won't work for me without a bunch of machine work. Already have another one on the way, so this one needs to go.
Basically, it is an aluminum ribbed set-up for a blower drive hub, so a stock balancer hits the front ribbing , and the cam drive hole is big for a fuel pump drive instead of a water pump. Someone modded it to make a water pump work by adding the bolt plate for another tin cover, but that wouldn't affect it with a fuel pump drive. It also has 2 sets of timing tab holes that would need to be sealed. Has normal corrosion on the back of the water passages, but sealed up fine for the last owner. (black line was an initial reference mark for machining the ribs away to work on my N/A set-up)
Asking $125 plus shipping, have Paypal...
Lurker
Discussion Starter #2
okay, found out Enderle sells a similar cover new for $125 .... price change to $85 plus shipping...
1 - 2 of 2 Posts
