1 - 11 of 11 Posts
I HAVE A 915 H/P BBC WITH A 1050 HOLLEY DOMINATOR THAT IS GOING TO BE CONVERTED TO E-85 MY QUESTION I REALLY WANT TO TO STAY WITH A MECHANICAL FUEL PUMP WHICH IS THE https://www.holley.com/products/fue...s/carbureted_mechanical_pumps/parts/12-454-20 WILL I BE ALL RIGHT WITH THIS WILL THE E-85 HURT THE PUMP THE GUY THAT IS DOING THE CARB SAYS I HAVE TO GO ELECTRIC UGGGG AND WANTS TO BE GET THIS PUMP HE SAYS PUMPING E-85 YOU NEED TO HAVE A FUEL SYSTEM FOR A 1200 H/P MOTOR https://www.product-engineering.net/products/standard-460-racing-fuel-pump I DONT CARE ABOUT ABOUT THE $$$ BUT DONT WANT TO HAVE ANY ISSUES RUN THE BOAT HARD AND HAVE LOTS OF FUN !!! ANY HELP WOULD BE APPRECIATED THANX !!
Pay attention to your carb guy. He's correct, and that would be a minimum.
The reason is, your engine is a 950 horsepower motor. Fuel pumps that give an approximate horsepower limit provide it for gasoline. E85 requires about 30% more fuel, by volume.
950 hp X 1.30 = 1235 equivalant. If you were to have a roots blower, add another 20%.
If your engine is not covered, I don't know that the USCG pump would be necessary.
pay attention to your carb guy. He's correct, and that would be a minimum.
950 hp x 1.30 = 1235 equivalant. If you were to have a roots blower, add another 20%.
If your engine is not covered, i don't know that the uscg pump would be necessary.
thank you
Some guy
you are correct i guess ill be going electric then .........
I would call George down at Clay Smith and ask his opinion. Fuel System - Fuel Pumps - Clay Smith Cams
The other thing you could do is something like I used to run on my turbocharged ski race boat, mechanical and electric pumps in parallel, with two one way check valves. I usually would only run the electric pump if I was pulling a fast skier or running hard.
i agree with you calling clay smith ! its ashame i the race pump looks like it was a good design and talked to a few ppl said some were good and few bad .....
The 6 check valve block mounted Clay Smith pump will do the job. With a bypass regulator. If you prefer belt drive the Ron's gold will work also.
I hate depending on electric pumps
1 - 11 of 11 Posts
