I had a customer bring up 3 block last weekend a Merlin 2, Merlin 3 which are older blocks and a new Dart Big-M with billet caps.
As I have posted many times I have had issues with the World SBC with lifter bore issues ETC.
I had 2 customers in the shop and they were devastated on the condition of those 2 blocks once probed out.
The first block I set in the CNC machine and probed out was the Merlin 2 block the cylinders on the left bank were in spec but the cylinders on the right side were moved a head .034 and guess what the lifter bores would not even clean up at .904 had to bush them.
That being said I also noticed on both Merlin 2 and 3 block the intake lifter bores were only 1.250 tall because they had counter bored the lifter bores to deep as you can see in the pic.
I am sure the engines should make more power with the proper seat timing events and lifter bores corrected or to blue print.
I had to machine the lifter bushings to the length of 1.375 as both blocks for some reason has really short lifter bores like the Gen 4 BBC. To put a 55MM cam tunnel in those block you would have to use a tall lifter bushing to make it work. Also had to clearance the block on one side from the deck to the top of the exhaust lifter bore on the left bank.
The Merlin 3 block the cylinders were in spec but the lifter bores just made it at .904 no bushings needed.
I ran into these problems about 12 years ago with the World SBC and always I was always told they would take care of me which never happened.
Hope fully the new owners of World cast Iron have taken care of these issues I have found over the years.
IMHO In the long run your best to deal with a company that does all the machine work in house and has a way to check and qualify their machine work !!!!
