pick up a cheap nitrous plate off ebay in good shape:
http://cgi.ebay.com/ebaymotors/NOS-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
cheap holley(knock off) black fuel pump for pressure:
http://cgi.ebay.com/ebaymotors/ProC...r_Truck_Parts_Accessories?hash=item2ea980499e
cheap methanol solenoid to control the plate:
http://cgi.ebay.com/ebaymotors/Devi...r_Truck_Parts_Accessories?hash=item20a9f12af7
turn it on with a msd rpm switch, have a methanol kit that's jetable for less than 200bucks
the biggest pro is you can feed the motor alil more timing and boost on pumpgas
Couple of things worth mentioning. Using a nitrous plate is going to give you no atomization. With out the nitrous your just going to piss fluid out of all the holes and its going to spray a lot!
The pump you've listed only makes 14 psi and isn't made for methanol. Our pump comes preset at 200 psi, bypasses internally for a smooth even flow and can be ran with 100% methanol.
The solenoid you listed is fine. We choose to use a one way check valve as they work nearly flawless and no wires to worry about.
You left out all the fittings you will need, hoses, wiring, electrical fittings, Not everyone has an MSD system to trigger the system so they will need a boost switch or throttle position switch to trigger the system. Not to mention the performance of the system isn't going to match that of a high pressure system like ours and the type of nozzles we use are far superior to using a nitrous plate.
When you take a look at one of our base kits which comes with no tank it's a pretty rock'n deal! Comes with absolutely everything you need. All the fittings you need, boost switch, 20 ft of 12 awg wire, LED status light, heavy duty inline fuse to protect the pump, heavy duty nylong tubing, one-way check valve, all the eltrical fittings and miscellanous hardware, intructions, technical support and LIFETIME WARRANTY for $240.00 bucks.
Not to shabby considering our competitors sell the same kit for just over $300.00.
Rodney
