Here's more stuff I rounded up while cleaning out the garage. All of the prices are + shipping. When responding (post or PM), please reference the item # as listed and the part. It also helps to provide your zip code so I can estimate the shipping. Thanks!! Jocko
1) Casale 12 degree 18% gears (helical cut).............................$150.00 (SOLD - SANGER-RICH)
2) Casale 10 degree 22% gears (helical cut).............................$200.00 (SOLD - BamBam)
3) HALON 5# (chrome) fire extinguisher (fully charged)...............$100.00 (SOLD - Maximus 2006)
4) Rex Marine billet (polished) fire ext. bracket..........................$50.00 (SOLD - jetjunky)
5) Billet (red, but can be removed) fire ext. bracket...................$50.00 (SOLD - Outlaw)
6) BBC crankshaft blower hub (internally balanced)....................$40.00 (SOLD - FLATMVN)
7) Cavitation plate thru-transom seal assembly.........................$20.00
8) Cavitation plate S/S water pickup, brand new.(to-10 AN)........$20.00
9) Polished S/S rope pop-up cleats (new) I have 4ea.................$15.00ea. (SOLD - slotracer)
10) Log seal (chrome) for 1" shaft..........................................$15.00
11) Rex Marine 3 3/8" diameter tachometer..............................$20.00 (SOLD - [email protected])
12) Auto Meter 3 3/8" diameter tachometer.............................$20.00 (SOLD - [email protected])
13) Billet aluminum hatch cover hinges (black powder coat)........$10.00pr (SOLD - widowmaker)
14) Fram fuel filter (flows 90 gph)..........................................$15.00
15) Autometer Pro Comp 2 5/8" liquid-filled water temp guage
(complete with mech. line and sender)...............................$20.00 (SOLD - Chris the Plumber)
16) Autometer Pro Comp 2 5/8" liquid-filled oil pressure guage
(complete with mech. line and fittings)...............................$20.00 (SOLD - Chris the Plumber)
17) Autometer Pro Comp 2 3/8" voltmeter...............................$10.00 (SOLD - Chris the Plumber)
18) Stewart Warner 2 1/8" boost guage (2-30 psi)....................$20.00
19) Stewart Warner 2 1/8" vacuum/boost guage.......................$20.00
20) Stewat Warner 2 1/8" mech. fuel pressure guage.................$20.00 (SOLD - Chris the Plumber)
21) Ignition kill switch w/lanyard............................................$15.00 (SOLD - Chris the Plumber)
22) BBC Carter mechanical fuel pump......................................$20.00 (SOLD - Chris the Plumber)
23) Moroso (p/n 73226) blue max 8mm plug wires w/ straight plug
boots. (brand new in the box)..........................................$20.00 (SOLD - Mike F)
24) MSD Pro Billet (p/n 85561) distributor. This dist. has the slip collar
so it will fit any Chevrolet V8. Includes 8mm Moroso plug wires.
This distributor is currently $340.00 from Summit.................$175.00 (SOLD - Dimarco21)
25) 2-pc. split driveline cover (chrome) 7 1/2" long, 5 14" I.D.....$20.00 (SOLD - Chris the Plumber)
26) Rule 2000 GPH bilge pump, w/auto float switch and West Marine
fused dash switch.........................................................$20.00 (SOLD - GregB)
27) Chrome bellhousing cover (for a budget boat buld)..............$10.00 (SOLD - Chris the Plumber)
28) Blower plate (o-ringed both sides). This is for running a bigger (10 or
12) on a 6/8 manifold)....................................................$25.00 (SOLD - APOLLO)
29) Ignition coils (both work fine) Holley (chrome)....................$10.00
Accel (p/n 8140)...................$10.00
Take both! for.....................$15.00
30) Bearing Buddy's (pair) p/n 1781. (brand new)......................$10.00
31) Billet aluminum guage bezels ---1ea. 3 3/8" straight.............$5.00
1ea. 2 1/8" (angled)............$5.00
32) BBC polished aluminum valve covers. These clear stud girdle
and offshore style exhaust..............................................$100.00 (SOLD - FLATMVN)
I'll try to include pics of all items on this first post. If unsuccessful, I will post them in my next post(s). Thanks, Jocko
