1 - 20 of 34 Posts
LAID IN MEXICO
1. solid driveline part. male for greek coupler 2.5" $15
2. oil pan-jet, gen 5 & 6, 14 qt dooley, with windage trey, new pump, pick up, and dip stick.(no damage) $300
3. pto crank button, BB FORD, for 1310 driveline. $30
4. drive line, 1310 (excellent shape), 7-3/4" long, (spacers can be added to lengthen) $50
5. chain steering wheel!!!, chrome, 8.5" round x 5.5" deep (slow and low) $50
6. two holley spread bore to square adapters. $10 ea.
7. propellor for v drive cruiser. michigan, ni-brail, 1" shaft, left hand, 13 -15, cup. $175.
prices do not include shipping!!, if my prices are off, and dont look right, tell me. im not looking to burn anyone.
1. solid driveline parts. male for greek coupler 2.5" $30
2. B&J in & out, with prop release. includes 16 spline flange for 1350 driveline. $ make offer (was in a blown gas flat)
3. oil pan- gen 5 & 6, 14 qt dooley, with windage trey, new pump, pick up, and dip stick.(no damage) $325
6. msd coil, #8201, pro power with polished alum bracket. $50
7. valve covers, BBC, classic MT alum. need to be polished or painted. $50
8. set of used taylor, BBC, wires with mallory pro shield covers (one bad boot) $10
9. pto crank button, BB FORD, for 1310 driveline. $30
10. drive line, 1310 (excellent shape), 7-3/4" long, (spacers can be added to lengthen) $75
11. chain steering wheel!!!, chrome, 8.5" round x 5.5" deep (slow and low) $50
12. comp cams, spring cups, new set, 1.75 od, 1.67 id, #4700-16, for 1.565 od springs. $20
13. pillow blocks for rail kit 90*, 2"x2"x2.5", powdercoated candy blue. $40
14. Rex pump tools, complete set, $160
pics coming tonight!!!
What is a B&J in and out with prop release ????
What the Hell is That?
LAID IN MEXICO
Discussion Starter · #4 ·
I think he Meant in and out BJ with Release. any pic's of that one? :D
it works as an in and out with a spring loaded lever (always returns to in when the lever is released), also is a ratchet type release, kind of like a whirl away. pics will be up soon, in fact there are some up in the v drive section. i just finished figuring out exactly what it is myself! look under help id this part!!!
Blown, OHBA Member
T valve
PM sent
LAID IN MEXICO
Discussion Starter · #13 ·
I'm interested in the coil and bracket. Does the bracket bolt to the cylinder head? Any chance you have a pic of it bolted up?
I am interested in buying it
thanks,
Todd
the coil bracket bolts to the rear of the engine on a BBC. it bolts to the top two holes on the bell housig / motor plate. it sits the coil just behind the distributor.
1 - 20 of 34 Posts
