1 - 3 of 3 Posts
Any suggestions on how to mount these seats. There is seat box glassed into the boat but I'm not sure how to secure them. I was thinking lag bolts but I was thinking they might rip out fairly easy... Any thoughts?
Couple ideas for you. They make a rivnut type of nut for wood/plastics that will bite into that and use whatever fastener size and style you want.
Or, get a hole saw and knock a hole in the dead center of the holes just big enough that you can reach in and put t-nuts on the underside.
I've done both
I'm no expert, but this is how I did mine. The hole is so I could get my hand in and put nuts under the mounting plate. I drilled 4 more holes on the outside corners and bolted my seats down. I couldn't get the photo to rotate.
1 - 3 of 3 Posts
