1 - 12 of 12 Posts
I run a BTM box, but now have it blocked off. The problem is the BTM box will retard it too much when you start making boost. Now I run my turbo motor locked at 29 degrees.
Official Test Driver
6m or equiv box is fine. No need for all that retard stuff when running full load. Proper tuning is the key.
Sent from My Boostpower Marine Efi Beacon.
I guess i won't buy one! Lol thank you. It was going to be added safety as I dont have waste gates. Summit said it was discontinued. Lol I'll look into the better msd. Alot going on w trans swap too so was trying to save a little.
You'll be fine without it. Enjoy!
I bought the msd6al2. Worked awesome. Started at 38deg and pulled out 10 at 8 lbs. I don't want to hurt it! Run 110 in my bow tank and 100/91 in the sides. It's much better cruising and maybe just piece of mind when WOT. Has iron Chevy heads w some work done. So my weak link for now. I have no afr or waste gates.
Comparing the 6AL2 to a TBM is like comparing a Iphone to a bargin basement flip phone. Actually worse.
Yeah, but you still cant go fishin with those phones like you can with the old hand crank magneto phones, they dont make near enough power :D
1 - 12 of 12 Posts
