1 - 10 of 10 Posts
I am replacing the throttle cable on my 21 Daytona and I can't seem to locate a cable end that connects to the Nicson gas pedal. The old adapter has a 10/32 female thread on one end and a 5/16" hole in the other. Through all my internet research, I haven't been able to find a replacement. I'm not sure if this was a factory piece, or something homemade.
If anyone has an idea where I might find this part or a comparable replacement, please let me know.
Thank you
Not sure if that is Nicson stock or not but can you unscrew the adaptor on the pedal and put a ball type connector on? I have two like yours and neither have that end. Interested to see if anyone else has the same as yours.
My nicson doesn't have the end the op shows.
Some guy
Thank you
I think if you look around you can find a rod end that would be 10-32 thread with a 5/16 hole. Might call Rex Marine, didn't see one in their online listing, but there was something similar that might be made to work.
Thanks for all the input guys.
I have looked into replacing the original piece with a ball joint style, but haven't found a ball stud long enough to get the cable end to clear the slot in the pedal mount plate.
I also considered a rod end, but can't find one with 10-32 female threads on one end and a 5/16 hole on the other. I may have to try to recreate the original piece with a scrap piece of steel or aluminium.
Any other suggestions or ideas, please chime in.
check with mercruiser that is there piece. I have seen them before on many boats.
I've done every google search combination I can think of to find a duplicate of this piece, but haven't been able to find another one like it. If you have any idea where I might locate one, I would greatly appreciate the advice.
Thank you
Well, after wasting way too much time searching for a suitable replacement for the original piece, I decided to just take an hour away from re-wiring the boat and make a replacement myself. Summer is coming quick and I have too many other things to get done on the Daytona to let this hold me up.
I appreciate everyone's input and suggestions.
1 - 10 of 10 Posts
