Status
Not open for further replies.
1 - 4 of 4 Posts
I have a few parts left over from a motor job I did on a 2000 PCM EFI Chevy 350. I have the intake manifold with the throttle body, IAC sensor,and about 5 maybe 6 good fuel injectors. I have the ignition coil, manifold temp sensor, and the raw water circulating pump. This was PCM multiport Apex fuel injection system. I have no ECM or harness. The stock exhaust manifolds are in good shape as well. The risers have been removed from the lower manifold so they will need the gaskets. Sorry will put up pictures tomorrow.open to offers a on what you need. Thanks Mike
Discussion Starter #2
here is the coil and Crank mounted raw water pump
pics, can't get the picture to load on the exhaust manifolds and MPI fuel injection. will try and take new pics asap. Thanks Mike
MPI intake manifold pictures
I did a motor replacement and guy left his old motor so i still have these left. I removed a couple injectors and the map, and TPS.
The Ignition coil and raw water pump are still availble. open to offers thanks Mike
manifold
Hello, give me a call or text tomorrow on what you want for the manifold setup, 928-580-6668, yuma az
Garrett
1 - 4 of 4 Posts
Status
