i had hell all weekend with fuel volume on my nitrous. i flowed the plate saturday and the deadhead quikfuel regulator i'm using had to show 14psi just to maintain 10psi at the solenoids over a bucket. on the motor i guess its pulling it outta the plate faster than the regulator can keep up with so i need a regulator that is a log type, which only bypasses excess pressure, not "regulate it". the fuel pump can keep up with demand, just having regulator issues. i had to open the quikfuel regulator alllll the way open sunday just to make a 1000ft pass on the 1st stage :mad: tried to run the 2nd stage, and sure enough, at 3/4 track it'd shut the nitrous off till pressure built up again :mad: got beat once yesterday because of it shutting off at 3/4 track just as i ran this guy down:|err
anybody know of a log type regulator i can just bring 2 3/8ths npts fitting off of and maintain 10psi constantly? don't think a holley or quikfuel deadhead types will ever work, i'm gonna have to bypass to keep up with volume needed. thanx for the help fellas :)devil don't wanna go back on the 4th with a sick nitrous set-up ;)
are you sure you want a "log" and not just a bypass (return type) regulator.
bud, i'll use whatever i can to maintain 10psi to my solenoids ;) got any suggestions? i'm open to anything.
A bypass regulator is what you need man
Not sure how many times that subject has been debated here but if you go to Hot Boat site and search bypass regulator you will get a ton of info.
THANX FOR THE INFO GUYS :)devil
