1 - 15 of 15 Posts
I am doing an intake swap on my 460 and figured now would be a good time to do a cam swap. I want a cam to have a lopey idle and have good vacuum....What does everyone recommend? I have an edelbrock performer rpm intake and edelbrock carb on it right now.Also,its a 20' Southwind with a berkley jet
ive come across a lunati cam...here are the specs
idle-5000- duration at .50" 207/213 Lift int. .503/.535
or a crane cam
1500-4500 duration at.50" 204/216 lift int. .487/.518
All and any info will be greatly appreciated,
Jon
i'd shoot for alil more duration to help the heads breathe, exhaust ports are horrible on those heads:)sphss you're not gonna get away with much more lift, but you should be able to pull off 530, and make sure you upgrade springs:)bulb
Seriously off center
I run a Comp 280H with .530 lift, and 230 deg @.050. No problems with logs and reversion, but I'm not comfortable with more duration than that. You may need to machine the spring seats for this lift.
Thanks for all the info! What does everyone recommend if I am running logs?Also should I just leave it stock?Its a 70 block if that matters
You can get away with a little more duration but OEM Ford heads like a alot of split. I would look for something like 215 on the intake and 230 on the exhaust at .050". Make it around 540 lift on intake and 500 on exhaust.
www.highflowdynamics.com
or a crane cam
Jon
Jon,
Don't know enough about your engine combo, but if the longblok is essentially stock then the Summit Cam p/n SUM-3501 will work for you. 0.503"/0.503" - 218*/228*@0.050 - 114 LSA. Close to what Straub recommended and with the "good vacuum" you desire.
Next power ugrade: ditch the Edelbrock carb for a Holley 850 cfm Double-Pumper.
LO
Jon,
LO
Thanks for all the USEFUL INFO!!!!!! This is a new "game" for me...With that cam,will it give me a lopey idle?Also,can I use the stock valvetrain or would I need to upgrade?
ATTA BOY
Same cam i have and its been a great cam. Nice lope to it too
76mph at 5k with this one.
did everyone upgrade their valvetrain or keep the stock push rods and lifters
With the OEM valve train in good operational order, the SUM-3501 Cam & Lifter kit will work without any other modifications, assuming the typical new camshaft break-in procedures are followed. Any more camshaft than that and you had better upgrade several areas of the valve train (exactly which parts get upgraded depends on the camshaft selected).
LO
1 - 15 of 15 Posts
