Will the neovane 755 flow more water than the 505? considering that they use the same impellor and the only diferance is the intake size. should the 505 be good enough for a blowen 427? I can only make 1 pass and water temp goes to 210 and just doesnt seem to be enough.
I had a neovane pump not sure of the size, and it started to leak a lot, then I bought an RB props water pump, and it gets the job done on cooling a blown 454.
the best thing you can do with a neovane pump is to take it off and throw it as far out into the river as you can
