When you buy a new boat complete with motor, What are some of the things I should be concerned with:)sphss? What do I look for:)Unsure? What do you look for? And how do you know what you bought(gearing, etc) with out breaking evrything down.
-Service the v-drive
-Get the prop checked for cracks
-Make sure the steering chain has a bolt through the last link that the cable wraps around
-Tighten all bolts
-check the strut bushing
-New impeller on the water pump
-Service the bearings on your trailer
-tighten bolts on driveshaft
-add more grease in u-joints, shaft log, and rudder seal
Some more will come to me, but that is a good start
Take a screw driver and tap (handle end) the floor around the v-drive area and the engine area on both sides of the stringers and around the strut area to make sude there isn't any delamanation going on.
Thanks Billy-B
Thats a good one to file away for future reference.
Also look for discoloratoin in the wood on the floors
and stringers.
Break Out Another Thousnd
Make sure there is a safety collar on the prop shaft, right in front of the strut log.
Check for slack in the steering cables, they should be like guitar strings.
