Here's the new production high performance trim pumps from BJ's Marine. These pumps can be used on a number of different applications, but our primary usage is for Place Diverters. This is a fully equipped pump with a simple four wire connection. Each pump includes a weather tight 4 wire plug with wire leads for easy wiring. It requires a 12 gauge positive, a 12 gauge ground, a 16 gauge up wire, and a 16 gauge down wire. you can operate this pump with any 6 pole or 3 pole momentary switch. No diodes are required.
Total weight is 7 LBS. They feature a clear anodize billet aluminum mounting plate with easy plug and play relays. In the event of any type of relay failure, you simply un-plug the bad relay and plug in a new one. No tools or wiring is required. I designed this plate system to be functional, easy to mount, and light weight. The pumps include fittings to accept -4 AN lines. Pumps complete and ready to run are $580.00.
