Here is the new stainless steel one piece investment cast prop to replace the steel one that chucked a piece at CFW. As always, you can never just do one thing. The taper between the two is very different (the old taper was real deep), so I will have to shorten the shaft about 3/8" to bring the new prop back closer to the strut. The old one is 11 1/8" X 16" and the new one is 11 1/4" X 16". There is a lot of difference in the blade configuration, and there is quite a difference (cup) in the trailing edge of the new one. I hate these type of changes-probably will require a gear change and a readjustment in driving (again). Stab and steer time to see what happens.
bulb
Denis
Denis
