1 - 17 of 17 Posts
Hello All, I am new to this forum but have an old hat at boating. However this is my first Jet Boat. I grew up on the lake and can remember when my dad had his 18' Flat bottom 455 olds jet, (dont remember what hull), but i have wanted one ever sense. I now have a 1979 Sunkisst 18' 460 berkely pump, jetovator. I just got it friday and LOVE it... Guy told me it was a 70+ mph boat, but as typical bragging goes, he was wrong. GPS today showed 62 at 5200 rpm. now to the questions.
I realize that the easiest way to equate speed is RPM.
1, I am looking to target about 75 mph if possible, Does anyone know if the 79 sunkisst hull is capable of 75?
2, it does not have a scoop intake but it picks up water great, does the drag you create by adding the scoop intake outway the gains, or are the gains worth it?
3, is there an increase in top speed with a droop snoot , and what are the negatives
4, ride plate , Pros and cons???
5, Last but not least, I own a macine shop and we build performance engines for cars, I am wanting to build a roller cam, roller rocker, 7000 rpm 460. question is what rpm can the Berkeley Pump handle and what rpm do i have to start worrying about blow out? also will blow out be a problem if i do the intake scoop i asked about earlier?
ANY AND ALL OPINOINS APPRECIATED.
I know not all of you want to answer, but if you have .02 i want to hear it and will consider it all before deciding, i plan to post my decisions and share the results with you all.
Thanks to you all in advance,
George from Georgia with his new toy!!!!
Horsepower sells Engines
im not going to be much help but nice boat. 7000 rpm that thing is going to need to push some huge #'s. that thing is going to be a wicked motor cant wait to see the pics. if theres not much done to the pump i think you would want focus on that
Wanted to add a pic of the pump to get help identifying it and see if they even make a droop for it, I think its a 12JC, let me know if you know...
Thanks George
Thanks George
Geeezuz......can you plant seeds with that too? or is it limited to just plowing:p
Congrats on the new float...
Looks like you've got a Berkeley JC pump. It's a decent starting point. you can run a place diverter (or trim, which you have) but in order to add a droop or straight snoot you'll need to change out the bowl to a split bowl, where the nozzle unbolts from the bowl.
Before you even start thinking about that motor...do your research. I don't know a lot about hulls, but I do know that most of the older shallow V bottoms get kinda sketchy above about 85mph.
You don't need to spin that pump to 7000.
Here's a link to Duane's impeller cut/horsepower chart. Not 100% accurate due to a bunch of other variables...but it's a pretty good idea.
http://hi-techperformance.com/images/Impeller Curves.jpg
most pumps come stock with an "A" impeller. If you want 7000rpms, you'd better make about 1100hp.
The first thing you should do is go over the hull itself. Make sure the stringers and floor are solid and there's no rot...take care of anything that needs work.
Then dive into the pump. A loader (scoop) will be of benefit at higher speeds. The condition of the impeller/wear ring is most important though...there are tons of threads in here on pump work/maintanence. Search and read up.
...and do something about that color scheme.
Living in a cage of fear
Welcome to rehab.....and congrats on the new addiction!:)hand:)devil
Rethink your engine. My BBC is roughly 625 HP, and spins an "A" impeller to 5800 RPM, at 86 MPH. (79' Miller hull)
I also had a stock JC pump at first. I modified it with a JG 2 piece bowl, a droop, and a diverter (as well as having the pump gone through and replacing the impeller with a stainless). Then had the intake re-set and added a very basic shoe (the "scoop" you mention) and ride plate.
I also added a loader to the intake.
If I did it again, on different boat. I would not do it all at once. I can't say what addition was the best, because I did it all at once. (The diverter and 2 piece bowl would be the best bet though)
I would start with the 2 piece bowl and diverter. Then perhaps the droop snoot. If I then saw any cavitation I would add the loader. If I wanted to improve from there, I would then add the shoe and plate.
I know nothing about your hull though, and that is just the general order I would do it.
Jet pumps are different than a propeller.
They can only absorb so much HP.
The pump does not care if the boat is moving or tied to the dock. It does the same thing regardless.
Build an engine that can run for extended periods of time, and live comfortably at 5000 - 5500 RPM or so, while making 550-650 HP and you will achieve your goals if the pump is working efficiently. (and the hull is capable)
Concentrate on oil control, and build it for endurance, while keeping it under 6000 RPM.
Several members on here have big inch Ford motors that produce incredible results at lower RPM's than 7000.:)hand:)hand
BTW, when I bought the boat it was much slower than yours with a crap "re-builder" 454. I don't think it went 45 MPH.
After building the engine, it went exactly 70 MPH. After the pump mods it did 86.
86 with an IMpellor
and
105 with a PROpellor
hil:)hil:)hil:)hil:)hil:)hil:)hil:):)devil
Extra bullet
Since you own/build engines, you'll understand me when I say, build the big roller deal as a "spare bullet", and leave the existing engine alone. When the "killer" is ready, stick the original under a bench somewhere for use when the roller spits out a part or two.....That way, you can still be on the water enjoying your jetboat.....I too, build engines, and I will say without a doubt, a jet boat is the toughest thing you can ask an engine to do. Vehicles sorta coast after a cruising speed is reached, feather the gas, and maintain the same speed. Not so with a boat, and especially a jet boat. Back off just a little and you're going to slow down, so the engine is under a constant load/RPM condition and depends on the boat "drying out" to relax a little.....Been there, done that......Vehicles hook to the ground, jetboats hook to nothing, and as such, 75%+ of boat performance will be found in a very expensive modified pump.....Engines are cheap, compared to pumps........Ray
Your Sunkisst is the heavy lay up as proved by the pic of the guy walking on the deck. On my Kisst you cant even lean on the deck, very light lay up. Your hull would be safe up to around 75-80 without professinal set up and make a great lake boat.
well another sunkisst owner, hell yea. i also have a 79 sunkisst but i have a 429 bbf with around 500+ HP and im around ur target mark for speed. torque is the key for a jet and look into the pump see wut cut it is and go from there. heres my sunkisst..
Mine is a light lay up as well, i am scared to walk on it like that cause is for sure would break through, that "GUY" is a 4 year old little boy who weighed about 25 lbs. So question is what is your hull good to? I have just enjoyed it the last couple of weekends. It has been a blast, just not fast enough. I am ready for speed, i sm used to outboards with serious speed, my last Laser was running a mod vp bridgeport running at 117 on radar. This 62 mph crap sucks.. but it handles like a BIA!!!
And is such an adrenalin rush...
im friends with MICHIGAN DAAAAAA and trust me ur little boy would go thru the hull if he stepped on it like that lol. hes at or around 80MPH. i just did the vinyl stripes on his boat a month or so ago, heres a pic....sorry squeek lol
1 - 17 of 17 Posts
