1 - 17 of 17 Posts
I have one of these sitting in my garage. I have no need for it now.
If anyone is interested, let me know. I'd take $100 for it and at that price I'll pay for shipping. You will need to buy the O2 sensor.
SOLD! Thanks guys.
http://www.ngk.com/afx/
still got the manual and other stuff? i might be interested.
sorry, i thought it datalogged too, i need 1 that'll datalog.
nice price though, someone otta grab this up!!!!:)devil
Impatient1, check out the Dynojet Wideband Commander (http://www.widebandcommander.com) and Wideband 2(http://www.dynojetwb2.com). I can hook you up on either of those.
i appreciate it keith, but i think i'm gonna go with the same wideband f.a.s.t. set-up we put on my uncle's turbo motor, it'll datalog and does on screen playback, its just a biggg display to have to find a spot for:)sphss be nice if someone would develope a nice cheap in-dash digital/sweep style gauge setup that would datalog as well.
How big is the display? Have you seen the touchscreen LCD? You can playback logs on that, plus record up to 186hrs on a single 1gb SD card. It will record AFR as well as RPM and one 0-5v analog input (MAP or TPS usually). 3" diagonal full color screen.
damnnnnn, dats niceeee:)devil it'd be awesome to have air intake temp with the 5volt circuit! the fast display isn't nearly as big or nice:)sphss my msd system datalogs rpm/boost/timing(came with a 2bar map)
21 Daytona
Do you have a good source for replacement O2 sensors? the cheapest place I've found is $75 for a Bosch wideband
Ah come on. 12 channels, including virtually any AF monitor, plus built in 2 axis accelrometer, gps speed, RPM, and GPS lap mapping and lap times (cool for cirlce racing:)devil)
http://www.racepak.com/Circle_Track/G2X.php
I got a big bad RacePak in my pickup and in my little boat...but for the $479 that WB2 and LCD sell for retail, you can't even buy the main unit from RacePak.
the wb2 is the 1 you posted a pic of? that's not to far off from the f.a.s.t
goin with the wb2 kit from keith:)devil that thing is badassssss for the money! i'm not even gonna put a tach in the dash, i'll just mount the display so i can see it clearly.
1 - 17 of 17 Posts
