Fogger?
To be safe I usually run the fuel at least 6 steps larger than the nitrous, also a little more retard. Then after watching the plugs make changes if you must. Remember the compression goes to 16-18.1 immediately, so it's necessary to be rich rather than lean.
6 steps larger? You cant be serious. 6 sizes smaller on the fuel side maybe.
Companies like Nitrous Pro Flo's and NOS etc. etc. jetting maps recommend square jetting like .028N/.028F at 6-7psi. and that will be dead dead rich in air that we run in, guaranteed. IMO, right off the bat you would want to pull .004 out of the fuel side and run it at a minumum of 5-3/4 psi. and get a plug reading, still rich I bet but it wont kill itself.
The best method is to send your entire system out to a guy like Steve Johnson, Jeff Prock, Koehler injection, etc. and have the system flowed. They will actuallly flow nitrous and fuel though the system and setup the jetting so its right on the money. There is a nitrous/fuel ratio that you want to target and they will get it there for you. The alternative is do it off of plug readings and that takes alot of laps to get sorted out. You will see nothing like .028/.028 in a system that has been flowed, more like .032/.022 or something like that.
I know of a deal where a supposedly good nitrous tuner had his tune up in this manifold when it was sent out to get flowed, the guy flowing it flowed his existing tune up which was .028/.028 @ 6 psi. and apparently he was running enough fuel in it to support a .040 nitrous jet, nice tune up huh. A tune like that is on the leaner side of what a company like NOS would recommend.... Its hard to hurt them from being lean, Ive activated my system 3-4 times with no fuel at all (mistake) and never hurt a thing, it just laid over and I got off the button.
I went and helped out on a dyno session with a nitrous motor last year and the manifold had been flowed, after looking at the tune up on paper I was thinking it was gonna be way lean but the A/F ratio was pretty much perfect, a small fuel pressure change and it was dead nuts perfect, well worth the money IMO.
Just rambling about n20 tune ups....
CS
