1 - 20 of 21 Posts
sitting for 3 yrs.460 ford.Drained the oil out the oil ext hose through the pump (PLUG DRAIN) first got a lil sludge then clean oil,(filter oil was clean)but before i put new oil back in,any suggestion on what i could pour in to clean the pan of any sludge...and let run right back out...to loosen up or clean out the pan.thanx mouz
Thanks will do! there was'nt much ,it could have been in the drain hose.
....like warm apple pie
You usually want to change the oil while its warm. Oil has suspension properties in it and the junk would be in the oil, not on the bottom of the oil pan and it would drain with the oil.
You might want to consider putting new oil in. Running it for a day on the water and draining it while its still warm. It will help 'flush' it out and get that crap off the bottom of the oil pan.
Thats how I would handle it. ;)
No Sandbar To Far
Run a quart of ATF in it for a day.
thanks will do both.deisel then new oil w/atf and will run it at elsinore monday for a hr or so and bring home and drain,put new oil in and filter ....
"It's HONDO, honey"
Can i get a amen :)devil The diesel fuel can be kinda risky you cant rev the motor, only let idel for like ten minutes. And honestly if it hasn't run for say a long time and it is nasty oil the diesel and old oil is like sand on main bearings. ATF is still oil and is has inhibitors that keep it from burning and contains good solvents to keep the valve body in the trans clean. :)bulb
thanks..the diesel i wont start just pour in and drive around the block and drain...thanks
Crank case "cleaners" of any kind are very risky IMHO. they do thier job of removing deposits very well and you run the risk of some of that sediment being left in the low reaches of the pan (hard to effectivly drain on a boat) only to be drawn up to the screen . When I get a vehicle with a concern of sludge or varnish etc I do several short interval oil changes with a good detergent oil . Those oils have properties which surround dirt and deposit particles and safley carry them off . my 02 Tom
*recently worked with an Atty on a deal where a quick lube joint sold him a crankcase clean , vehicle only made it from Ventura to Bakes ,the residual junk that didn't drain, plugged the oil screen about 90% ,Smoked the lower end
I'm with you Tom. The last thing you want to do is take those carbon deposits, sludge, or whatever out of suspension and have them floating around the engine. Seems to me that might be an expensive problem. Imagine if one of those carbon deposits made it up next to the piston skirt and cylinder wall. Carbon is hard stuff and is usually what makes up sludge.
~Brian
Discussion Starter #16
READ IT..it recommends atf with oil change only..thanks..i will do oil change add 1 qt auto trans fuid only a couple times..thanks everyone.
Discussion Starter #19
great article..
I never hit bottom.
Engine and transmission flushes are being sold left and right, but are they a good idea?
A New "Recommended" Maintenance Item...
In the last few years you were probably asked, or told, by you dealer or quick lube place that you need an engine or transmission flush, because the engine oil or transmission fluid is very dirty. They will tell you that it is recommended that you have it done because your engine or transmission will last longer if it is flushed clean. In that they are correct, a clean engine and transmission will last longer. But is flushing the best way to get a dirty engine clean?
What Is An Engine Or Transmission Flush?
Flushing is the high pressure forcing of fluid back against the normal flow of the fluid. In other words if the normal flow is left to right, the flush would force the fluid right to left. This is accomplished by connecting a machine that will force special solvents back through the engine and transmission. The idea is that by forcing cleaning solvents backwards through the system, it will get all the junk and garbage that has formed over time and "flush" it out of the system. In theory this may be sound, but in actual practice, it's dangerous.
The Dangers Of Flushing...
Flush machines do what they say; they force high pressure cleaning solvents back through the engine and transmission and clean out some of the accumulated junk that has formed. Now engines have small passages and galleries through which oil or automatic transmission fluid flow and there are one-way valves that keep the fluids from backtracking for whatever reason. By using an aggressive cleaning procedure like flushing, large chunks of accumulated sludge are broken off and forced backwards through these galleries and valves and, more often than not, lodge tightly and block them. This cuts off the normal flow of the fluid and causes lack of lubrication in an engine and abnormal or no shifting in a transmission. The results are expensive repairs, or more often, engine or transmission replacement.
Who Recommends Flushing As Maintenance?
The shops that want to sell you the engine or transmission flush charge anywhere from $49.95 to $99.95, not including a new engine or transmission. Those are extra. And they state quite emphatically that it is recommended that it be done. But who actually recommends that it be done? I checked with GM, Ford, Chrysler, Nissan, Honda and several other new car manufacturers and not one recommended an engine or transmission flush as routine maintenance. In fact, they specifically don't recommend it at all!! The new car dealerships that do sell them use the implication that since they are the dealer that it must be the factory that recommends it. And if they do say the factory recommends it, they are flat out lying to you.
The only ones who do recommend flushing as a maintenance procedure are the companies that sell the flush machines and the shops that buy them. The flush machine manufacturers state quite clearly in their operating manuals not to use their machines on "high-mileage vehicles". That simple statement proves that flushing is not a safe procedure. It also absolves them of any responsibility of any damage that may occur due to the use of their equipment. This leaves the shop wholly responsible for anything that happens and the cost of correcting the damage that occurs.
I know this since I recently appeared as a witness in a lawsuit where a person was sold an engine flush that destroyed his engine.
The Facts...
The fact is, if you do frequent engine oil and filter changes and service the transmission every 15,000 miles there is no need for a flush. I have customers that change their oil every 3,000 miles and they don't need to use fancy oils and filters, and after over 100,000 miles, the oil comes out almost as clean as it goes in. They have regular transmission services and their transmission still shifts like new, even with well over 100,000 miles on it.
If you have neglected regular oil changes and you want to do some interior engine cleaning, get the oil and filter changed and replace one quart of motor oil for one quart of transmission fluid. The transmission fluid has a high detergent content that will clean the engine without damaging it. Do this every 3,000 miles and you will clean the inside of the engine slowly and gently.
If you do get a flush, I recommend you do it when you can afford to replace the engine or transmission.
1 - 20 of 21 Posts
