1 - 9 of 9 Posts
Idaho Jet
I have an olds 455 in a jet boat and I can't figure out how to drain the oil out of it! i do have a oil sucker that usually fits down the dipstick tube, but the smallest tube doesn't fit down it.
the oil pan drain is under the engine.
so any ideas?
Craig
Head Janitor
so any ideas?
Craig
You *could* take the dipstick off and put the tube directly into the pan.
Once drained (assuming you can get to the drain plug) put a hose with a threaded plug on it.
That does work...just make sure you disconect the battery first.....
That doesn't have a car pan does it?
Unscrew the oil filter put a pan under and roll over the engine and pump it out. I take the plugs out to relieve the compression, takes only a couple of minutes. I have a remote so I only have to use the out line.
Idaho Jet
This is a good idea! But it won't hurt the motor turning it over wouhout any oil in it?
I just checked mine....with the dipstick tube pulled out of the block there is a 3/8 i.d. hole that a suck pump will fit down......pumping the oil out with the oil pump won't pump all the oil out...pickup could be 1/4-1/2 off the bottom of the pan.....and no....cranking over with no oil pressure or spark plugs PROBABLY won't hurt anything....but it is an olds:)sphss
Or you could get a replace plug for drain plug all set up for a hose deal......
pile a gang of rags under the pan and hot swap them out. My olds would siphon 8qts in about 40 min with a 3/8 id drain hose....I did use a piece
of clear hose so i could see where the oil was when i started the siphon
1 - 9 of 9 Posts
