1 - 15 of 15 Posts
Head Janitor
I don't have an oil temp gauge (though I realize that's the way to know)...but based on others knowledge; do you guys think I need one?
Engine is a 550 hp aluminum LS1.
Cruise RPM is 3500-4500 rpm; max rpm is 6100 rpm. The boat is a jet boat with a stainless B impeller.
how far/long do you cruise?
how big of an oil pan?
At those engine speeds that is some hot oil after a few miles.
S CP
Head Janitor
I move all the time, so cruise length varies depending on the size of the water....but typically in the 1-3 mile range; not short by any means...sometimes up to 10 miles.
The oil system holds 8 quarts.
Fuel is premium unleaded.
I was looking at the thermostat controlled units so that I don't have to worry about oil being too hot/cold.....
what oil do you use?
A cooler wouldn't hurt you one bit, you'd be surprised as to how hot your oil gets. You should see about putting a temp gauge in at the oil filter just to check.
S CP
Highaboosta
The mistake I made was I put the cooler on at the same time as I put the gauge on.
Then I realized it takes a long run at high speed/load to get the oil up to even 220 without ANY water flowing through the cooler. Now it's all plumbed in and I wish I didn't have the heavy ass thing on there.
Head Janitor
S CP
Mobil 1 10w40.
I will probably heed the advice and put a temp gauge on first. My theory (which could be wrong) is that using a thermostatically controlled oil cooler would help both scenarios...
Mobil 1 10w40.
Good oil... and yes a thermostat on the cooler is a good idea
S CP
Head Janitor
The only thermostat controlled remote oil cooler I can find is the one sold by Hardin. Are there other/better ones out there? Maybe one that includes the oil filters as one piece like the one GN7 posted in another thread?
$$$$ and they take up space.
S CP
S CP
Here Jon, let allow me to fix that a tiny bit.
They do take up space. But compared to a remote filter and remote cooler, not really. The only benefit to the seperate pieces is you can splkit them, but then you adding unecessary line length.
I kind of giggle when I think what I paid for that cooler. The second one I bought was a little more, but still roughly the price of a used remote Olson.
at the end of 10 laps what's your temp?
S CP
Perfect. For a grouchy old bastard!:wink2: Sorry, I've been painting (my shop) all day and in a mood.:wink2:
Thats using the water exiting the superchiller.
We can get it 260-275 with the right straight 50 conventional. Higher on a course like Puddingstone.
I am only a grouchy old bastard when on the key board. My fingers are total pricks. I am, on the other hand a mellow, grandfatherly grey hair.
1 - 15 of 15 Posts
