1 - 11 of 11 Posts
21' Daytona
Anyone ever make their own ? I'm wondering out loud what's involved in building one ? Is it as simple as a tube in a tube, or more complex ? I'm thinking about making my own to fit my boat and having it painted to match.
jetboataholic
You could probably just coil up a bunch of copper tubing and put it inside a larger tube. The oil would run through the copper tubing and the larger tube would be filled with water. If you know how to weld and fabricate, I don't feel it would be too hard.
Hope this helps.
Hope this helps.
The coil would be too restrictive.
21' Daytona
Hope this helps.
Yes it does. I just was wondering what would be involved. My thinking was to make one to fit a specific location on my boat. Efficiency and flow would concern me though.
Use a heat exchanger off a 4 banger boat motor...they work very well.
One part at a time...
I have an intercooler off a 2007 Seadoo RXP. Could make a tube to go around it? It's about 3 inch diameter. Heres a pic...
jetboataholic
Alright, how about having the oil fill the large tube and run the water through the coil.
But, how would it be too restrictive to run the oil through the coil?
1 - 11 of 11 Posts
