I just orderd the bypass kit from Summit last night - 9.55 for the part, 9.25 shipping LOL. I already have the dual remote filter top. I decided to go remote so I could install a Masterlube to pre-lube the motor. I couldn't really find a good spot to tap in an oil line for the Masterlube - the oil pressure fitting seemed too small, and too far downstream.
I was thinking of drilling and tapping the block itself for direct feeds to the AN fittings, rather than using an adapter, but I chickened out. That, and I saw the check valve in the block-to-filter adapter, and figured that was needed so I wouldn't prelube the oil pump.
