1 - 2 of 2 Posts
Idaho Jet
I have a olds 455 in a tahiti hull. I took it out Saturday and ran it and found that the distribtor is leaking oil and running down the rear of the motor. i checked and the O-ring looked good and it was sealing when installing the dist.
Any thoughts? do I need a flat washer between the block and Distributor?
You could make a gasket or use rtv silicone for a good seal.
1 - 2 of 2 Posts
