Personally I have never understood why they don't make screw in pickups and be done with it.
Yea it's a v drive and most of the ones i've seen crack at the weld I was wondering if I was doing it wrong,it has a mount at the far end of the P/U . Guess I'll clean it up and re tig it,i mig mine, tack weld in position on a mock up block then i weld it all the way around also i have found that the pickup support needs some extra support on a v-drive pickup where the pickup is mounted on the far end away from the pump. they tend to vibrate and crack on or near tube.
Tig w/ silicone bronze.Yea it's a v drive and most of the ones i've seen crack at the weld I was wondering if I was doing it wrong,it has a mount at the far end of the P/U . Guess I'll clean it up and re tig it,
