This is stuff I think about...who desinged and knew the proper angel, when useing a open-end wench
They allways seem to fit..
But not the angles and offset of a combination end wrench. I believe that was worked out in the factories during WW II.Solymon Merrick patented the first wrench in 1835.
Or wenches with wrenches??
I'm quite sure I'm not alone when I say I have "modified" a few for a more proper fit... More so the box ends, like for the front inner bolts of an Enderle hat, but also a pretty good collection of bent up open ends when the designed "proper angle" just wasn't quite right.... Boats are easy compared to cars/trucks that have assembled drive trains before the body goes on... Just once I'd like to see a GM, or Ford, or Chrysler engineer have to work on their stuff when it is a completed assembly.... I won't even get into the "special angles" required when dealing with aircraft or ordnance.... You see, those "cheap" tools are good for something....This is stuff I think about...who desinged and knew the proper angel, when useing a open-end wench
Ray[/QUO
10-4
I have modifed hand tools to suit my needs, like everyone else...I was amazed yesterday how you can usually grab atleast one flat when needed
never paid that much attention before..............
Hey we are converting to the metric system inch by inch!!The rest of the world did! Just you guy's are just a little behind. this is a map of countries still on the imperial system..Unsure
The 2 metrics were factory fixes for stripped threadsI replaced a water pump on an 82 GM 2.8 once. It had 9 bolts holding it on. 6 were two different sizes SAE and three were metric. Guess they couldn't make up their mind.
Tim
