my v-drive flat is overheating,the water pump impeller checks fine and water flows thru motor at idle fine but at speed the temp just climbs past 180 and will run upwards of 210 or more if i dont shut it down,engine is hot! steam is rolling out the over flow but water stops flowing out overflow after it gets to about 180. it's like the pumps stops pumping for some reason after a cooldown the pump flows water at idle just like it should.
pulled pump cover and impellor is fine,checked and flushed all lines for obstructions and found none. you would think the water being pushed thru the water strainer alone @ speed would be anough to keep it cool ?
new motor 565 alum heads,34 locked out timing full msd system,dry headers,pump gas
have had this flat for over 30 years with the same water system and it has never ran hot. anyone?
