yeah, i don't know why you would even bother with trying to make a turbo work with an engine compartment. especially when a procharger is a turbo....just belt driven, so it acts very similar and they make as big a prochargers as you want to make power. I also want to get a cover over my engine eventually which is one of the main reasons i went with a procharger. tons of power potential, 10-12 lbs with a big procharger will make 1000hp easily. toss on another 8-10 lbs and your in the 1400-1600 hp range. they also work really well with the blow thru carbs which Impatient and Hass love, but efi is what i am doing...same with Outlaw and obviously Unchained is efi.
with either big turbos or big procharger you can pretty much build anything cu. in. wise and still easily make 1000hp. I'd just see what you can find in regards to good deals on quality parts, then just see what you come up with. I ended up with a 502 because i had real nice 4.0 billet crank that came in the engine i bought complete. also had a tall deck with some long rods, but i almost went with a 4.5 stroke because i had a line on a really nice crank, but it didn't work out so i went another direction....all i'm saying is that you can build whatever you want and make that power no problem, just make sure its some quality parts. And believe me there are some killer deals out there right now, which really cut down on total cost of the build...i love used parts, most of the quality parts out there are very... very lightly used. unchained is running some used rods, i am too...shoot...pretty much the only new part i have in the rotating assembly are my je pistons. just my .02
AP
