1 - 20 of 275 Posts
26' Sleekcraft
My winter project started with stripping my 26' 84 Sleekcraft down and taking her over to Pat's Fiberglass in Upland. They added several bulkheads at stress areas and one over the bed area. Also they extended the bed area out another foot. The drop down area at the dash on the driver's side where the gauges mounted was cut off evenly across. The side panel was strengthen. Over a hundred holes were filled. The boat was just flipped over last week and a few small cracks were found. So far everything looks to be going well. The gel-coat colors and the layout is still not agreed upon though red and white is a must. Any ideas?
26' Sleekcraft
Once they started to grind out those cracks on the bottom they found a section of a lifting strake that had bad glass. You can tell by the white color of the glass. They will need to take the glass down then build back up the lifting strake.
Part of the floor will need to be cut out to glass the other side. Don split the costs with me of this unexpected repair which made the wife happy.
Renegade jet
If you fill in those windows, I think there will be very little light in the cabin, as those other windows are very small. Great thread BTW and keep the pics coming.
Boat Nut
Last time I talked to Finney's they still could make the sky lights for the top.
High Performance Marine
Boats looking great!
Theirs always gonna be those hidden imperfections in glass work , That you just dont see until you dig into it. Glad to see Don is helping ya out on the bill.
Keep up on the progress pics.
26' Sleekcraft
Been working on the trailer while Pat's fiberglass has the boat. I found a body shop that takes Itex. That's a barter service that excepts trade skills.
Here they are rounding off the corners on the bow latch bracket.
Took the back tires off to help with moving around the lot.
Added a underneath spare tire carrier. Getting prepared for that hot I-40.
A second cut out for additional LED taillights.
I added this slanted box for my trailer light plug. I didn't like the way the plug was alway bent when plugged in.
26' Sleekcraft
Discussion Starter #14
The boat has been flipped back over to repair the other side of the cracks.
The floor was cut out also and they found the glass broken away from the stringers and the hull. Sleekcraft had only glassed one side of the stringers to the hull about 1" out. You could move the stringers from side to side with your hand.
26' Sleekcraft
Discussion Starter #15 (Edited)
This is a photo of the stringers after they were re-glassed and properly attached to the hull.
A bulkhead was added at the bilge area to keep any bilge water from running forward. A 1" plug was added so no water would get trapped forward.
Cut outs for the cleats.
A new floor was put in and glassed over.
Hatch cut in making sure it's a flush fit.
26' Sleekcraft
Discussion Starter #18
I was looking at the boat today and the upper edge of the boat between the arrows is sinking inwards vs the outside edges along the bow and the stern are sloping outwards. I asked Don what's up with this and he told me the weight of the cabin over the years is forcing the edge inwards. Tomorrow they will try to jack it back into position and place bulk heads to correct it.
40' of Skater
Wow, that is alot of work!!!! Looks great though, congrats!!:)devil I agree with you on the side windows, they will look much better filled in. My boat is going through a similiar rebuild. Keep up the good work!!
Erik
1 - 20 of 275 Posts
